Anyone had experience w/HD reduced effort clutch kit?
Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Has anyone had any experience with a HD reduced effort clutch kit installed on a TriGlide? I would like to have an easier clutch pull on the TG. Any comments or info would be appreciated. Thanks.
I was told it will not work with the TriGlide since they have a Heavy duty Performance clutch to handle the extra weight of the TriGlide.
The Triglide comes with the ramps but not the spring. The spring is the same one they put on the CVO bikes and due to the extra weight of the Trike and torque of the engine it is needed. One solution would be to install VP70t from these folks it will make the clutch pull much easier.
