Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Solution to the burning leg
Old 08-18-2009 | 05:05 PM
jackfiss's Avatar
jackfiss
6th Gear
Originally Posted by Boom
Sales rep told me that on the '10s, and you are idling in the heat of traffic, you can twist the throttle forward and the rear cylinder will kick off. Once you twist the throttle to give it gas and accelerate, the rear cylinder kicks on again. Same setup on the '09s?
The 10's as well as the 9's need to have the set-up turned on in order to do this. It will come on by itself when it hits a certain temp (285). Not sure where the sensor is but it doesn't take too long before you feel it go down to 1. Sure is alot better than the 8's with the exhaust re-routed. We were out in Rapid city on 8's and it smelled like an iron was on our jeans in traffic.
Old 08-18-2009 | 05:49 PM
TheJimer's Avatar
TheJimer
Originally Posted by jackfiss
Anyone using the engine management? Seems to kick in as soon as it comes to temp if you sit at a light. I guess this is a good thing.....
The heat problem isn’t just at a stop light; I’ve hand my legs toasted riding along at 40mph. Lets say that you are heading North and have a cross wind from the West; the wind blows across the hot engine and cooks the inside of your right leg. Make a U-turn and come back heading South and the inside of your left leg will fry! Now granted, I operate in 100-115 degree outside temps. and the outside air hitting you in the face is even warm but I never experienced engine heat like this on any of my other bikes.
The EPA should be forced to ride in these conditions and maybe, just maybe they would think twice about imposining these silly regualtions!
I know, I know I'm
Old 08-18-2009 | 08:16 PM
robandlyn's Avatar
robandlyn
So with all the heat they give off maybe I will leave it that way so we can
ride all Winter. I'll have the Lynn lead and melt all the snow for me .... LOL ....
Rob ....
Old 08-19-2009 | 12:26 AM
msocko3's Avatar
msocko3
Front head towards the left side of where the induction module bolts on to the intake port.
triked
113
08-31-2011 07:01 AM
Diesel-Dawg
24
02-24-2011 11:57 AM
iaff84
44
09-15-2010 07:31 PM
ultraride09
06-12-2009 06:01 PM
Scooter Wench
05-31-2008 10:01 AM
Quick Reply: Solution to the burning leg
