Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
reverse problems
Old 06-24-2009, 05:23 PM
triked's Avatar
triked
triked is offline
Default reverse problems
Has any one else experienced the triglide trying to go into reverse while going forward? This happened to me.
I was riding in the rain for several days and the unit started to try to go into reverse without any warning.
Old 06-24-2009, 06:20 PM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
I have not experienced that yet. Were you at a stop when this happened??
Old 06-25-2009, 04:16 PM
triked's Avatar
triked
triked is offline
I was going down road at 35mph when reverse motor kicked in and tried to lock into the back gear.
Old 06-25-2009, 05:03 PM
hogmanharry's Avatar
hogmanharry
hogmanharry is offline
6th Gear
Default going in reverse
i hope this is not gona happen every time it rains,im thinking of getting one,i dont want that kinda trouble.
Old 06-25-2009, 07:14 PM
oldmsocko's Avatar
oldmsocko
Have you talked to your dealer or HD Customer Service about this problem. That is not a good thing to happen. We must be going through the first year build problems. Just think, they haven't been able to fix the leak problems in the trunk seal so what will they do with a serious problem such as what happened to you.
Old 06-25-2009, 07:58 PM
carlo's Avatar
carlo
carlo is offline
I was thinking if a Champion reverse conversion could be installed on the Tri Glide instead of having the Elec reverse. The Champion reverse sounds like a better set up as it is in the transmission just shift the lever on the trans.
Old 06-25-2009, 08:18 PM
ON-3's Avatar
ON-3
ON-3 is offline
That's a major malfunction. To use reverse: (1) you have to be in neutral,
(2) you have to depress the enabler "R" button and (3) you have to depress and hold the "↓" button. All that and yours operated on its own! I'd be heading for the dealership ASAP.
Old 06-25-2009, 09:38 PM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
No problem with reverse on my TG.....
Old 06-26-2009, 04:52 AM
oldmsocko's Avatar
oldmsocko
That is about 1,600 plus what you have already spent to get reverse. HD needs to make it right.
Old 06-26-2009, 06:24 AM
carlo's Avatar
carlo
carlo is offline
I read yea hind sight being 20/20 If it were possible to of ordered my Tri with out elec reverse. And if the Champion reverse is a reliable setup I would of went for it. The Elec reverse is a pain to use pulls a lot of juice from the battery and can trip the breaker. Is the Champion reverse easy to get in and out of reverse ? any one have first hand experance using the Champion set up ?
Quick Reply: reverse problems
