06 TLE Carring Capicity?
So am I correct in figuring this out?
Sidecar empty is 234lbs, gross axle is 300lbs so its designed to carry 66lbs?
or
GAWR rear cyle axle weight 827
GAWR TLE axle weight -300
527 lbs total weight?
Or do I add the GAWR front and Rear and then subtract the TLE 300lbs GAWR? ie
GAWR Front 550
GAWR Rear+827
ttl 1377
GAWR TLE -300
1077 lbs?
Confused ;-)
TIA,
John
or
GAWR Front 550
GAWR Rear+827
ttl 1377
GAWR TLE -300
1077 lbs?
Confused ;-)
TIA,
John
So what is the weight? 66 lbs? Heck if I knew that I would of taken a pass on it as that is useless.
My 58 BMW Spezial Sidecar with the rubber band suspension handeled 200lbs w/no problem...
You know how the heck do you get in the car? I see the step but where its it at seems pretty useless. FWIW I have the windshield on mine perhaps taking that off would help? Then you have to put it back on once in the car?
http://www.flickr.com/photos/2134921...7620406700906/
Or even a windshield that folds forward like the BMW Spezial car. A door would be great but I suspect that it would weaken the tub.
John
John
If I'm not there helping, same thing with the feet, but she places her left hand on the seat back and right hand across to the padding on the left side of the hack.
Either way, it takes longer to explain it that it takes for her to get in.
Hope this isn't confusing.
