Decided on some speaker pods for the sidecar
can't pull up the photo on this CPU but I am sure it looks great given how good your bike/SC looks.
Having those rear speakers on both my Ultra's makes a difference for sure. Not so sure how much more of a difference for me having the speakers in the SC makes. Being it has a volume and such my wife says she doesn't turn it up too much because the 4 speakers on the bike are plenty loud for her. I imagine speakers in the fairing alone isn't enough.
Hey Abnmarine,
I sent you a private message a while back. I am still waiting on my Liberty to arrive but was curious if you could share information on how the electrical and brake hook-ups went? Were there any connectors provided or was it all cut and splice? How about the brakes? Are you using the stock master cylinder or did you change to one with a different piston size?
Hey Abnmarine,
The spotlight was tapped into the harness under the fairing. I used the stock MC but they provided the parts needed to allow the sidecar brakes to be added. None of the install was hard. Most time consuming item was installing the triple trees.
Also, the wiring harnesses have a quick disconnect in case needing to remove the car.
