Sidecar for 2014/2015?
The wife likes the hack even though it rides a little rough compared to my 2011 FLHTP with a true Harey hack. The Hannigan body is mounted to the sidecar frame, the harey sidecar s set up on leaf springs kind of like a baby buggy. The Hannigan rig sits lower and I can get in the curves better. Lots of fun o drive.
I love it. It is my third rig. I talked with Herb at Hannigan a long time to get it the way I wanted it. They are good people to work with. It is a heavier rig than the true HD, but if I don't want to be passed on the highway I will make you work for it. I have rolled it up to 100+, but no trouble cruising at 85
Thanks...that makes sense and doesn't screw up an already working intercom. I need to talk with Hannigan some more...really like the way your rig looks and think it's exactly what I'm looking for. Factory 2 year warranty is up in November and am trying to decide about the extended warranty vs the sidecar issue voiding the warranty. Local dealer in Huntsville wasn't totally convinced adding the sidecar would void the warranty and is looking into it for me. I just had the auxiliary light switched replaced and picked the bike up yesterday (they said they replace 2-3 a week. Crazy on a newer model to be having switches go out). As far as the Hannigan goes - did you get a sidecar brake installed? Of all the things, that's the one thing I'm most leary about monkeying with (no pun intended) given the reflex brake stuff on the bike. I'd hate to tap into the stock break setup and have issues.....and the sidecar disk brake on the Ural (beginning in 2014) has been more problematic than when I had drum brakes on the hack. Still, the Ultra Limited is significantly heavier and capable of higher speeds and I can see where an extra brake could come in handy.
Yeah, put the brake and the ECC on mine ,no problems with the linked brakes the scooter. You could call Herb at Hannigan and he could give you the list of everything I put on mine. I am well pleased with all f their work. The sidecar brake is so good tat it des pull some to the right if you use the rear brake only. Apply a little front brake and she is straight. I am thinking about installing a proportion valve to back the hack brake off a bit.
