running tire backwards?
The sidecar tire doesn't get the abuse that the front and rear motorcycle tires do. I only got 5K on the rear motorcycle drive tire of my TLE probably due to flying the car all the time. If you get less than 10K on your front tire then a rear tire on the front will give you better mileage. Mounted in reverse the MT90-16 Commander II tread is oriented the same as the stock tire mounted in the proper direction and has almost twice the tread depth.
The reason, so I've read in the link below, for running a rear tire reversed on the front is so the splice does not come apart.
The back tire having more tread lasts longer.
http://cyrilhuzeblog.com/2009/08/23/...by-avon-tyres/
