CptCeeJay:
I had gotten a couple of PMs about my pipe similar to your query, so guess I'll post this up here for all to see.
The pipe I am using ... (it was ~$275 from Paughco) ...
http://paughco.com/2008-catalog/indi...20Paughco.html
didn't fit quite right (hung down at a bit of an angle), so I had a friend at a muffler shop put a little bit more of a bend (guessing about 5 degrees) in the front headpipe where it turns to the rear to get it to set horizontally ....
[Since the Touring and Dyna are both "A" type motors, not sure why it didn't fit the same (horizontal orientation) on the Dyna ... although when looking at stock Dyna pipes they seem to hang down just a tad bit ....]
I got some take-off heat shields off the forum classifieds (although Paughco sells them, too) ....
I made my own muffler bracket for Paughco P/N 603 ...
I attached a threaded stud and spacer to the bottom of the stock bracket ...
A headlight mounting block was inverted and screwed into the bottom of the stud ... a piece of 1/8"x1-1/4" zinc-plated steel stock was then bolted to the headlight mounting block horizontally between the muffler and the swingarm ....
There's a channel on the inner face of the muffler and two "T" bolts connect the muffler to the other (aft) end of the steel stock ....
I contemplated trying to put on a fishtail ... may still give it a try later ....
P/N #605 is $95 plus shipping ... I think it might work with my current setup ... it's 31" ... there is also a 36" version of the same pipe (P/N #605-4) ....
Since I am using a ThunderMax with AutoTune I had to switch to pipes with O2 bungs ... ('05 OEM ECM is 'open loop' so does not use feedback from O2 sensors) ....
The pipes come either with or without O2 bungs ... the 733C9 has them ....
I did not have to shorten (or do anything with the rear pipe) ... mocked it up after making the 'adjustment' to bend the pipe up ... and it worked okay ... I think there was enough 'depth' in the 'Y' joint that the rear pipe could just slip down into it a little further ... your results may vary ....
R/
'Chop
