tour pak usb hookup
There is a 12 volt outlet kit sold by HD tht is relatively easy to install then you just get a USB outlet adapter that plugs into the outlet. The HD kit is 'keyed power" . It only provides power with the switch in the on or acc position. Just change where the harness get's it's power source from ( a connector under the seat near the battery to a "hot all the time" source.
USB charging point for Tour Pak
I use the TAPP-HD, see link, mounted in the tour pak, which is set up as detachable. They have a direct to battery style if that is preferred.
http://www.3brpowersports.com/products.php
Pluged into the AUX switch with a splitter from HD so I can still use other items on the switch.
