013 road king with Abs Brake line arangement
I recently installed ape hangers on my king and used the LA Chopper kit. The "T" that bolts under the triple tree has the lower abs line coming out the front and up into the nacelle and then back to the abs module. However when I turn the bars to full right the line kind of curls up a little. It does not bind or kink or pinch at all. Is this normal or something I should try to re-route?? I don't see any other way it can go. And also a guy I had seen at the HD dealer near by said that theres going to be some movement no matter what and as long as no rubbing or pinching occurs not to worry. Any input would be greatly appreciated. Thanks in advance
Moogs
01-31-2018 08:44 PM
