Why is my paint chipping away?
I am rattle can painting many parts on my bike. I started with the lower forks this week and I have a slight problem. I sanded down my forks with 80 grit sandpaper, primed it, and then painted it with an additional 4 coats. After doing that the paint job looked great, but the paint chips away really easy. Is there a way to fix this problem? I should also mention that I am going with a matte black paint so I can really use a clear coat. If you have any suggestions please let me know how to fix this, I have a HOG meeting to go to on Sunday.
Thanks,
Phil
Thanks,
Phil
RE: Why is my paint chipping away?
Bobcowan - I used paint thinner to clean it initially. Then I sanded it down to nothing but bare aluminum, which created the texture.
SprigerGT - It is flaking just to the primer.
I live in England and it's not the warmest weather here right now. I am painting the tube in a bay that is somewhat heated, maybe about 60 degrees. Do you think that has anything to do with it?
I've done some auto painting in the past, so here's my two cents. After your first sanding (80 grit) and cleaning use a tack cloth to remove any particles from the surface. You should sand (200 grit) you primer coat and use the tack cloth again. Apply topcoat/s and if you are using a matte finish with clearcoat to follow, one final wet sanding with 1000 grit.
Question
Rattle can paint has a shelf life, how old is the paint?
60 degrees F shouldn't be too cool for painting, what's the humidity? Paint will pick up excess moisture during application.
Question
