Spring Riding Tips
Spring Riding Tips
SPRING RIDING TIPS
Well, Old Man Winter's finished up with his annual business. Summer riding means preparation and planning ahead.
TIRES & WHEELS
Along with all the routine spring services, it's a good time to take a close look at the tires. Would now be a better time than later to reshoe the old horse, or are the tires in good shape? The tire's tread should have at least 3/32" depth at the thinnest part. Most tires have safety bars incorporated into the tread pattern. When the tire wears down to a certain point, the safety bar will cause the tread pattern to appear as though it were smooth all the way across for about a 2" wide swath. Also, don't neglect to watch for weather checking and cracks in the tread or sidewall area. If you've elected to "re-tire", this might be a good time to check and repack those wheel bearings. Ideally, you should pack the wheel bearings in the fall, prior to putting the bike up for the winter, but if you didn't, tire time is the best opportunity for this little chore!
BATTERIES
And speaking of old, how old is the battery? Has the bike been sitting idle for a long period of time? Was the battery kept on a regular charging schedule? If there's any doubt about the condition of a battery, don't wait until Murphy's Law strikes (and it always does - at the worst possible time and place).
OIL
If your scooter has been hibernating all winter without an occasional foray out into the world, the initial start-up may hold a surprise. Most Harleys (except for 1993 and later FLT/ FLHT models and Dyna models) have a tendency for the oil in the oil tank to seep past the check ball in the oil pump and fill the bottom end of the engine with oil. If your H-D is earlier than model year 1993 (Big Twin; 1991 for XL's), and the crankcase breather is still routed into the air cleaner compartment, it could make a major mess when you fire it up that first time. This is a phenomena referred to as "wet sumping". When the engine starts, the scavenge side of the oil pump begins returning oil to the oil tank. Because there is such a large quantity of oil to pump out, the pressure created by the downward stroke of the pistons forces the excess oil out through the crankcase breather before the oil pump has a chance to evacuate it. A good way to prevent this from plaguing you is to check the oil level before you start the bike. If it appears a little low, disconnect the crankcase breather line from the air cleaner and route it either to a catch pan or back to the oil tank filler opening before starting the engine.
FUEL
Another annual problem area that keeps surfacing year after year is the dreaded curse of rotten fuel! Today's pump gas has an approximate shelf life of about 3 weeks. If you're one of those conscientious types that drains the fuel tank and runs the carburetor dry before putting the bike up in the Fall, you still may not be out of the woods. It's almost impossible to evacuate all the fuel from the tank and carb. Exposure to air increases the rate of decay. So a very small amount of fuel left in the transfer ports of the carb can turn into a major pain in the neck when you begin the new riding season. Most pro bike mechanics recommend filling the tank and adding a good quality fuel stabilizer before storing the scooter (make sure you run the bike for a mile or two to ensure the treated fuel makes it all the way through the carb). This cuts down on the potential damage caused by both moisture and fuel rot. If you do experience stumbling or engine misfiring due to fuel starvation and other related carb problems, the quickest fix is to disassemble the carb and flush out all the fuel ports with carburetor cleaner. Extremely stubborn deposits may require manual cleaning. Note: This is a very delicate procedure and should only be performed by an experienced technician! After the carburetor has been reassembled, you'll probably want to put the scooter on a diet of fuel treatme
TIRES & WHEELS
BATTERIES
OIL
FUEL
hawkdriver77
Exhaust System Topics
08-27-2007 12:33 PM
