My Security transmitter dont transmit???
I just installed a smart siren and pager security unit on my 2005 Road Glide. Has anyone had a problem with the smart siren not transmitting to the pager? I followed the directions very carefully but I dont get a signal from the siren? I did read that it may take 4 hours of riding/charging of the nickel 9volt battery before the siren operates correctly. Is that the problem? Has anyone else installed or had this problem? Thanks in advance ,,,,,,,,,,,,Mike
I could not find my pager manual but I did find this by another member.
1. Ensure the pager receiver is turned off
2. Press and hold the pager receiver button (D) - (the big button on the front of the pager). The pager receiver will flash and vibrate to indicate it is in the ON mode. Continue to hold the button until the LED indicators begin to flash one after another and the receiver begins to beep once every two seconds. The pager receiver is now in the encoding mode. (NOTE: the encoding mode will time out after beeping five times. If it times out repeat steps 1. and 2.)
3. Press the Security System Key Fob once to arm the security system. The pager receiver will indicate that it has been successfully encoded by beeping four times.
HD_Rider
05-06-2012 01:45 PM
