Riser bolt deliemma
Riser bolt deliemma
Hi, all. I need some help with an odd situation. I have a nice set of old risers I want to use on my '95 springer softail. My problem is the hole is 1/2 " and my risers have been heli-coiled for a 3/8 or 7/16 bolt. What I want to know is can I use some type of spacers, grommets or something to fill in the very small gap? Heck, I even think duct tape would do it. Any suggestions?
thanks
thanks
I did that a long time ago. First of all, duct tape will not work. I used 1/2 inch round stock. A buddy who owns a machine shop cut it to the correct length, and then drilled it out with his drill press to the correct diameter. It fit like a glove.
TwiZted makes a good point, though.
Crazy
Crazy
