2007 Harley FLHTCU rear wheel removal
Welcome to the forum.
If you do not have one I recommend getting a manual. It will not only help you to take off the rear wheel but many other projects you will incur.
Remove saddle bags
Remove mufflers
Jack bike up
Remove E clip on end of axle
Take axle nut loose
Remove axle
Push wheel forward and work belt off.
Pull wheel out from under motorcycle.
Remove saddle bags
Remove mufflers
Jack bike up
Take axle nut loose
Remove axle
You can get the electronic version of the HD service manual, along with the wiring manual, for about $10 off Ebay. It's the actual HD manual- not third party...
