Which braided cables?
I hate steel braided cables and I will tell you why. First where they rub they will cut what ever they rub on like a rat tail file. Then the braids fray and when every you get near them they cut you like a pin cushion. If you get the ones that are plastic coated the coating turns yellow. This is from the view point of a mechanic as I have been cut by braided lines and cables a LOT! But they do look good but that is all.
![Smile](https://www.hdforums.com/forum/images/icons/icon7.gif)
I went with goodrich (sp) for brake lines and drag specialties for throttle. I think if you get proper hold downs, ie: cable to frame clamps, you can minimize abrasion. Did this when I went to mini-apes. Not that big of a cash outlay, if they get frayed, they'll get replaced. Actually made a noticable difference in braking, that's a good thing.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
