Specs & Prices on 05 V Rod
VRSC V-Rod
Official Factory WebSite:
Harley-Davidson Motorcycles
Base MSRP $17,695
DIMENSIONS
Length 93.6 in. Seat Height Laden(1) 26.0 in.
Ground Clearance 5.6 in.
Rake Steering Head/Trail 34.0º / 3.9 in.
Wheelbase 67.5 in.
Fuel Capacity(2) 3.7 gals. Oil Capacity 4.5 qts.
Weight Dry Weight 596.0 lbs.
POWERTRAIN
Engine(3) Revolution®
Displacement 69.0 in.³ Bore x Stroke 3.94 in. x 2.84 in.
Engine Torque(4)(5) 74.0 ft. lbs. @ 7000 rpm
Fuel System(6) Electronic Sequential Port Fuel Injection (ESPFI ) Compression Ratio 11.3:1
Miles per Gallon(7) Carb. N/A ESPFI 47 hwy / 37 city
Primary Drive Gear
Gear Ratio (overall) 1st 11.752 2nd 7.898 3rd 6.322 4th 5.459 5th 4.889
WHEELS/TIRES
Wheels(8) Front Machined cast aluminum smooth disc
Rear Machined cast aluminum smooth disc
Tire Size Front 120/70ZR19 60W Rear 180/55ZR18 74W
ELECTRICAL
Electronics Standard security system
Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout; tachometer
Indicator Lamps Oil pressure; engine diagnostics; coolant temperature
CHASSIS
Brakes (diameter x width) Front 11.5 in. x 0.20 in. dual Rear 11.5 in. x 0.23 in.
Lean Angle (per SAEJ1168) 32º / 32º
Exhaust System Slash-cut duals
COLOR OPTIONS(9)
Vivid black, black cherry pearl, chopper blue pearl, lava red sunglo, rich sunglo blue, two-tone chopper blue pearl and brilliant silver pearl, two-tone black cherry pearl and black pearl, two-tone smokey gold pearl and vivid black, two-tone vivid black and lava red sunglo UNIQUE FEATURES Chrome, two-tone silver and charcoal engine; hydroformed perimeter frame with silver leafed aluminum powder-coat and clear-coat; 49mm forks raked out at 38°; 26" seat height; 3.7-gallon fuel tank under seat; radiator shroud with twin vortex air scoops; teardrop reflector optic headlight.
VRSCB V-Rod
Base MSRP $16,895
DIMENSIONS
Wheelbase 67.5 in.
POWERTRAIN
Primary Drive Gear
WHEELS/TIRES
ELECTRICAL
Electronics Optional security system Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout; tachometer
CHASSIS Brakes (diameter x width) Front 11.5 in. x 0.20 in. dual Rear 11.5 in. x 0.23 in.
COLOR OPTIONS(9)
Vivid black, black cherry pearl, chopper blue pearl, racing orange, anodized aluminum
UNIQUE FEATURES
Polished, two-tone silver and black engine; hydroformed perimeter frame; black frame, calipers, brake lines, rear shock springs and hand controls; 49mm forks raked out at 38°; 26" seat height and adjustable handlebar; 3.7-gallon fuel tank under seat; teardrop reflector optic headlight; radiator shroud with twin vortex air scoops
Base MSRP $17,695
DIMENSIONS
Wheelbase 67.5 in.
POWERTRAIN
Primary Drive Gear
WHEELS/TIRES
ELECTRICAL
CHASSIS
COLOR OPTIONS(9)
VRSCB V-Rod
Base MSRP $16,895
DIMENSIONS
Wheelbase 67.5 in.
POWERTRAIN
Primary Drive Gear
WHEELS/TIRES
ELECTRICAL
COLOR OPTIONS(9)
UNIQUE FEATURES
