Specs & Prices on 05 Softail
Softail Standard FXST/FXSTI
Official Factory WebSite:
Harley-Davidson Motorcycles
Base MSRP $13,695
DIMENSIONS
Length 95.0 in. Seat Height Laden(1) 26.1 in.
Ground Clearance 5.6 in.
Rake Steering Head/Trail 32.0º / 5.0 in.
Wheelbase 66.9 in. Fuel Capacity(2) 5.0 gals. Oil Capacity 3.5 qts.
Weight Dry Weight 629.0 lbs.
POWERTRAIN
Engine(3) Twin Cam 88B™
Displacement 88.0 in.³ Bore x Stroke 3.75 in. x 4.00 in. Engine Torque(4)(5) 85.0 ft. lbs. @ 3000 rpm
Fuel System(6) Carburetor or Electronic Sequential Port Fuel Injection (ESPFI )
Compression Ratio 8.9:1
Miles per Gallon(7) Carb. 50 hwy / 42 city ESPFI 50 hwy / 44 city
Primary Drive Chain
Gear Ratio (overall) 1st 10.110 2nd 6.958 3rd 4.953 4th 3.862 5th 3.150
WHEELS/TIRES
Wheels(8) Front Laced Rear Laced Tire Size Front MH90-21 54H Rear 150/80B16 71H
ELECTRICAL
Electronics Optional security system
Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout Indicator
Lamps Oil pressure; engine diagnostics
CHASSIS
Brakes (diameter x width) Front 11.5 in. x 0.20 in. Rear 11.5 in. x 0.23 in.
Lean Angle (per SAEJ1168) 34º / 31º Exhaust System Staggered shorty duals
COLOR OPTIONS(9)
Vivid black, brilliant silver, sierra red, impact blue
UNIQUE FEATURES
Silver powder-coated engine and covers; hardtail styling with hidden horizontal rear shocks; black horseshoe oil tank; bobtail fender; raked front forks
Softail
Night Train FXSTB/FXSTBI
Official Factory WebSite;
Base MSRP $14,995
DIMENSIONS
Length 95.0 in.
Seat Height Laden(1) 25.2 in.
Wheelbase 66.9 in.
Weight Dry Weight 630.0 lbs.
POWERTRAIN
Primary Drive Chain
WHEELS/TIRES
Wheels(8) Front Steel laced Rear Black highlighted machined disc
ELECTRICAL
Electronics Optional security system Instruments Electronic speedometer; odometer; resettable tripmeter; diagnostic readout
Indicator Lamps Oil pressure; engine diagnostics
CHASSIS
COLOR OPTIONS(9)
Vivid black, black cherry pearl, black pearl
UNIQUE FEATURES
Black powder-coated engine with wrinkle black and texture black covers; laced front wheel, disc rear wheel; Badlander® seat; hardtail styling with hidden horizontal rear shocks; drag-style handlebar; black tank console, rear fender supports, air cleaner and oil tank; bobtail fender
Springer Softail
FXSTS/FXSTSI
Base MSRP $16,695
DIMENSIONS
Length 93.5 in.
Seat Height Laden(1) 25.2 in. Unladen N/A
Ground Clearance 5.4 in.
Rake Steering Head/Trail 32.0º / 5.3 in.
Wheelbase 65.4 in.
Weight Dry Weight 653.0 lbs. Running Order N/A POWERTRAIN Engine(3) Twin Cam 88B™
Displacement 88.0 in.³ Bore x Stroke 3.75 in. x 4.00 in. Engine Torque(4)(5) 85.0 ft. lbs. @ 3000 rpm Fuel System(6) Carburetor or Electronic Sequential Port Fuel Injection (ESPFI )
Base MSRP $13,695
DIMENSIONS
POWERTRAIN
Primary Drive Chain
WHEELS/TIRES
ELECTRICAL
CHASSIS
COLOR OPTIONS(9)
UNIQUE FEATURES
Softail
Base MSRP $14,995
DIMENSIONS
Length 95.0 in.
Wheelbase 66.9 in.
POWERTRAIN
Primary Drive Chain
WHEELS/TIRES
ELECTRICAL
CHASSIS
COLOR OPTIONS(9)
UNIQUE FEATURES
Springer Softail
FXSTS/FXSTSI
Base MSRP $16,695
DIMENSIONS
Length 93.5 in.
Wheelbase 65.4 in.
