General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I have a 2002 RoadKing with a ticking problem between 1000 and 2000 RPM when accellorated. I have installed gear driven cams, replaced lifter and added a big bore kit and a S&S Carb. I cannot determine what the noise is. Is there any help out there for me?
most likely just a harmonic vibration.....check the easy stuff like shift linkage and levers and pedals. Then move on to checking for loose bolts...motor mount is really common for vibrating loose.
