Diamond Cutting
RE: Diamond Cutting
Just got mine done here http://diamond-heads.com/pages/21742/index.htm Less than 10 days turn around.
RE: Diamond Cutting
Shooter, a little while ago I asked you a question about diamond cutting and you responded that there is a new cut called a double diamond cut. Do you know where I can get information or a picture of this new cut? Thanks
Was just informed that the Harley motor has fins that are too thin to handle a double diamond cut.
cut, cylinder, cylinders, davidson, diamond, fins, finsdiamond, harley, harleys, heads, motor, motorcycle, motors, thin, wwwdiamondheadscom
