150 rear tire for 02 road king
Hi I'm new to Harley Forums and I'm looking for some information on running a 150 rear tire on my 02 road king. I've seen the cycle visions spacer but what I want to know is that does it just go between my wheel and pulley or do I need to change them? Any info would be greatly appreciated. Thank you!
bobbob02
bobbob02
the 150 tire is used on the same wheel as your 130. not sure about the spacer, is that for the pulley? belt will be your only concern.it will interfere with the tire, if you can space the pulley out a little, prolly will take care of that. if you want to spend the cash, you can run a newer year/narrower belt and rear pulley.
