Torque Wrenches
RE: Torque Wrenches
You need at least two good quality torque wrenches ... in/lbs & ft/lbs. Plus a torque screwdriver in/lbs comes in very handy. Any good quality will do. SK Tools or K-D or Craftsmanwill do well for a few years of occasional use. Certified Snap-on, Mac, Matco or others are not necessary for the weekend wrenching.
Good Luck. Ride Safe.
RE: Torque Wrenches
Hey, Craftsmam does the trick nicely but never, never lone it to anyone. If someone abuses the wrench you must send it to be recailabrated. How do you know?, the sound of a snapped or stripped fastner and the cash register ringing. Inch pounds are very light mostly just marginal over hand tightening in most conditions. Foot pounds are much greater in value. There is a conversion factor sheet ( in.lb. to ft.lb.) with craftsman in.lb. wrench and a little window to confirm the setting(s). Note always return the wrench to zero when completed. notorious
RE: Torque Wrenches
Yeah my vote is for Craftsman, I've got two in 3/8 (one ft lbs, another in lbs) and a 1/2 which is good to 150 ft lbs. I also purchased a 1/2 one from Home Depot which is good to 200 ft lbs. I believe it's a Husky model. Good quality and the price was right. Torque screwdrivers are pricey and for most repairs, you should be able to get by with a 3/8 in lbs model.
Store them either in a case or in their own drawer of your tool chest. Always release the spring tension when your done with it. And don't drop them!!!!!
Most torque setting are in a range eg: 18-25 ft lbs (or in lbs). I usually try to hit it in the middle depending on the size fastner and where it's going. Also remember that most torque setting (unless specified) are based on dry (unlubricated) fasteners, and substituting a zinc (or other) coating can alter what the correct torque should be, as the plating acts as a lubricant. In some cases this can alter the specs by as much at 8-10 ft lbs depending on the size of the fastner.
Best to always use the 'correct' fastener everytime, or get a machinist quide to make your adjustments if the setting is critical.
RE: Torque Wrenches
That's exactly right. A zinc plated bolt needs only 85 % of the torque that a dry carbon steel bolt would take. Torque is also affected by motor oil, never seize, WD-40, basically anything on the threads.
