messed up got a little brake fluid on my paint
anybody else done this i was checking my fluid and the handle bar turned a splash of fluid got on my tank i wiped it off as soon as it happend washed the bike and waxed the tank hope its all right anybody got any input thanks
I had a little drip from the master cylinder onto the tank a while back. I wiped it off then washed the affected area and was good to go. If it would have damaged the paint, it would be showing by now. You be ok.
ALL dot fluid is corrosive
Anytime you work with dot fluid have a spray bottle with rubbing alcohol, anywhere dot drips or spills, whether it be @ the master cylinder, caliper or, any painted or chromed surface. Spray rubbing alcohol on the effected area. the alcohol will cause the dot to bead up. continue cleaning untill no more beading! Because it could take days or months, depending on the quality of paint or chrome, alchohol is the only recommended neutralizer for dot. Also do not scrub the area! you will rub fluid into the pores, and could instantly damage the integrity of the surface. Ie. see paint on the rag! Also, cover caliper and pads with a rag so not to contaminate either, brake pads, or rotors! the raw materials will instantly be compromised! See, squeaky brakes.
20RoadGlidin
02-01-2011 06:58 PM
