Turn Signal Lamp
Turn Signal Lamp
Howdy from Texas!
I have a 2008 Sportster and recently replaced the bullet turn signal housing asm. This one acts as turn signal and real lights. It uses a single filament lamp. After I replaced the asm the turn signal blinks the way it is intended but the running light will not come on. I double checked connections and the bulb is good. This is a 2 wire asm.
Anyone have any ideas?
How does it use a single filament lamp? Running lights and turn signals should use a dual filament lamp. Am I missing something in your post?
If you're using a turn signal and running light combo socket and are using a single filament bulb, it will not work. You either have the wrong socket or the 1157 dual filament has to fit. Did you get the proper front turn signal assembly?
If you are wanting to have a single filament bulb do more than just T/S duty (Run/Turn/Brake), then you need to install a controller to accomplish it....
A two wire system is a hot and a ground... PERIOD.... The Black is the ground, the Violet is the Hot for the signal from the TS/SM... no Fancy-Schmantzy bulb is ever gonna change the effects of how electricity works....
This is what I have been told also...
The dealer did give me the wrong part initially and it was a three wired one. But of course that was not correct.
I know I am missing something really simple here.
