Harbor Freight Wheel Chock
Old 06-30-2009, 08:24 AM
jknowlton's Avatar
jknowlton
jknowlton is offline
How does it "mount" to the ground?
Old 06-30-2009, 05:23 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
use a concrete drill and run some ancors, on my buddies for his rocket we just bolted it to a sheet of 3/4 ply and it works great as well
Old 06-30-2009, 05:28 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
If you use plywood, make sure it's long enough to go under the rear wheel, too. That will keep it from sliding when you back out of it.
Old 07-01-2009, 09:50 PM
TexasUltra's Avatar
TexasUltra
TexasUltra is offline
I use mine on a multi-use utility trailer. I was lucky enough that 2 of the bolt holes lined up with the cross piece of angle iron for extra strength. I also used stainless steel T- nuts from under the trailer so I don't have to crawl under the trailer to take it on and off.
JackGib46
04-13-2013 10:24 PM
goatdriver
08-14-2012 02:45 PM
Oceanrider56
09-28-2011 09:54 AM
TedMan
04-17-2009 04:40 AM
texas725
03-24-2007 08:28 PM
Quick Reply: Harbor Freight Wheel Chock
