Installing a Luggage Rack
Hi
I recently purchased a luggage rack that mounts to my detachable sissy bar. My question is the instructions say to use red loctite on the chrome mounting bolts. Now I remember reading a warning about when you tighten chrome nuts on chrome bolts, you can sieze the nut before you get it tightened all the way on. I read the tech tip about loctite and anti sieze and figure you can't use both at the same time and want to know if I use the red loctite as instructed, will I have to worry about siezing? It only gets 14 ft lbs of torque and I'm not sure if that is enough to cause a siezing problem I was thinking that is a problem for bigger bolts and more torque. The nuts to these bolts have little dimple on them that when you go to thread the nut on by hand, it stops before the bolt comes through the other side. This is a design to insure it stays tight as compared to regular nuts and bolts that allow hand tightening all the way on? I figured it will thread ok when pressure is applied by the torque wrench. Can this lead to siezing? just don't want to screw up the bolts before I get them tightened all the way and have the rack secure. Any advise will be appreciated.
Thanks in advance
Thanks in advance
