Head Light
RE: Head Light
If it is a standard fitting bulb (H4? but not certain on your make), you can replace that directly with a halogen bulb, no other work is required.
On the other hand, if you want to go HID - you will need a ballast and all the other stuff necessary, in that case it is better to buy a complete replacement light unit but those are EXPENSIVE!.
