Bike has been sitting--won't start
Hi all,
I have a '99 fatboy that I used to drive regularly up until a couple of years ago when I went back overseas for awhile, and it was left sitting in my garage for that time (sorry ). Well, I'm back and I'd like to get the beast back up and running in perfect shape again. Before I left the bike ran just fine, but now it wont start. It turns over but won't ignite, the extent of trouble shooting so far has been hooking it up to a fresh battery, but to no avail. Any suggestions as to where to start looking? I'm no genious when it comes to engines, but I'd like to at least give it a shot myself before I tow it to a professional (and I have the repair manual--I'm good with directions).
Thanks!!
Thanks!!
If you left the fuel in there for a a couple years,that fuel has probably turn to gum,varnish.Best thing to do is drain and rinse the tank,fuel line.Might want to replace the fuel filter or clean the petcock screen.
The carb should be cleaned also.Check the jets and needle/seat for for any gummed up gas.
1 Post
Thanks for the replies guys..!! Well I took the carburetor out and drained it and it definitely didn't smell like fuel, more like a paint-shop so I guess some of the fuel had gone bad. I cleaned it out as good as I could without taking the entire thing apart. However (and forgive me for using the wrong nomenclature here), when I engaged the throttle there was fuel leaking out where the "throttle arm" attaches to the carburetor...I opened that portion up and there is a membrane/filter right there, and I assume this is some form of secondary fuel filter??? I'm assuming that has gone bad and no longer seals. I am having trouble with photobucket at the moment but I'll try to get a pic or two up to help identify this part.
Now someone mentioned a fuel filter...I can't find one in-between the petcock (had to google that word ) and the carburetor..I assume an inline filter is not standard.
Again, thanks for your help guys...I may not know what I'm doing, but I still have a blast doing it....
