Handgrips Change?
Handgrips Change?
Hey guys, is it pretty easy to swap out handgrips on my 08 Road Glide? I am a little nervous taking the controls apart, is there anything to it? Anybody have any pics or can you guide me to a post that has some pics of somebody changing them out? Any encouragemnet would be appreciated, thank you!
Probably the easiest thing you will ever do to a Harley. Don't let the 08 throttle by wire scare you. purchase the grips for you bike, must be for 08 dresser and later. Take out the two screws to the switch housing and seperate it. Give the Throttle grip a hard tug and it will come right off, the new one just snaps right on. You will note the plastic gear plug on the end of the handlebar that mates up inside the grip to operate the throttle by wire. For the Clutch side, just seperate the housings, pull off or cut off, if glued on from factory, put on new glue and slid your new grip into place. The 08 and later dressers with the throttle by wire and much easier than the earlier cable type systems. Nothing to it.
Stroker
Stroker
