J&S Jacks....Dyna Usage question.....
Old 11-24-2008, 01:16 PM
Bad Example's Avatar
Bad Example
Bad Example is offline
Default J&S Jacks....Dyna Usage question.....
Tried calling J&S...had to leave a message. Anyhoo...When lifting my '08 Fatbob for the 1st time I noticed a slight rocking motion back and forth while lifting and when working on the bike. Since the jack is suppposed to be and looks extremely stable on the website I'm wondering if i"m using it properly. I'm entering from the exhaust side and making sure the rear lifting table contacts the frame just behind the tranny and also make sure the fornt lifting table contacts the frame, not any mechanical part. Is this correct? Any and all constructive commentary is greatly appreciated.
Newbie Steve
Old 11-24-2008, 04:49 PM
jokr's Avatar
jokr
jokr is offline
Ive been shopping for a jack for my softail and im impressed with the j & s jack. While doing my research I noticed that some of the jack companies sell an adaptor for the dyna's frame I would say you need something that goes on your frame.
Old 11-24-2008, 05:52 PM
0lowrider1's Avatar
0lowrider1
0lowrider1 is offline
i have a j&s jack,had it about a year now.my bike and others have been on there alot,mines on there now,doing a service and a few other ...uhhh...hmmm...let's just say tweeks...anyway mine is stable,i have a 01 dyna low rider.no adapters needed.had my buds 00 deuce on there not long ago.it felt really stable...just wondered did you have the locks engaged and the pressure let off ?
Old 11-25-2008, 11:22 AM
Bad Example
I think I've figured it out. I forgot to back off the pressure on the bottle jack once I had the bike lifted and the stop levers set. So there was still some lift pressure on the frame causing it to rock a little. Thanks for the comments. By the by....J&S called be back ina timely manner and went over usage with me. Great guys to deal with!
Old 11-25-2008, 06:03 PM
0lowrider1's Avatar
0lowrider1
Yes they are..nothing but good things to say about them,when mine arrived it had been dropped,the drain pan was trashed and one of the wheels was broken,i emailed them and they called me back and i had a pan and wheel two days later...now that was really cool..i highly recommend them...
Old 11-26-2008, 12:33 AM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
When I had a Dyna I had an adapter. If I recall an adapter is needed because the oil tank hangs below the frame on Dynas.
Old 11-26-2008, 12:39 AM
Romark's Avatar
Romark
Romark is offline
No adapter needed for a Dyna on a J&S jack. Rosie O'Donnel couldn't knock my '07 Wide Glide off my J&S jack.
Mark
Old 12-01-2008, 12:47 PM
Bad Example
Yep....had to back off the bottle jack...now she sits solid!!!
Bad Example
No adapter needed for the 'bob BTW....
Old 12-01-2008, 03:42 PM
ride99fxd's Avatar
ride99fxd
ride99fxd is offline
Mark
That's true, but she could probably do things to it that you wouldn't want to touch it without rubber gloves.
Quick Reply: J&S Jacks....Dyna Usage question.....
