Speakers shorting out
Old 05-27-2008 | 11:02 PM
JimiV's Avatar
JimiV
Stage I
Default Speakers shorting out
2002 Road Glide-Had a factory speaker go out and replaced both with after market speakers. They work fine while idleing but intermittently short out above 50mph. Never had the problem with the factory speakers. The bike is wired for QD Tour Pak with speakers. The wires for the Tour Pak are piggy-backed onto the terminals of the front speakers, don't know if that would make a difference.
Any ideas?
JIMI V
Old 05-29-2008 | 09:58 PM
Hanayaro's Avatar
Hanayaro
Stage III
Default RE: Speakers shorting out
You need to make sure you are hooking both the pos and neg from head unit to the speaker, then put some electrical tape around the terminals of the speaker so when you put it back in the door it don't ground out just isolate it from the metal you will be good to go.
azlou66
Audio Systems
07-07-2016 04:07 PM
GNR
Audio Systems
08-11-2014 12:41 PM
Lorenzo Alanis
Audio Systems
08-06-2014 03:00 PM
vhmike73
Audio Systems
26
03-31-2013 05:20 PM
18BKLR
06-11-2011 12:15 PM
