spit through carb & pipe evo
Old 10-03-2004 | 02:42 AM
bad bill's Avatar
bad bill
Stage IV
Default spit through carb & pipe evo
my 91 fxstc has a miss on front cyl.
all ignition changed, carb and intake gaskets,batt and stator checked.
my comp. checks show slight to no var. although, has a double up spit {ifyou will} on front cyl.
I am hoping for good-external-news!!!!!
thanks!!!
Old 10-22-2004 | 08:18 PM
BClem's Avatar
BClem
Default RE: spit through carb & pipe evo
Bad Bill,
Let us know what you found. The lean condition (backfire) should show itself with a bit of detective investigation - fun stuff... A sweet running engine is simple and a bore; what am I saying!!
BClem
Old 11-03-2004 | 11:33 PM
bad bill's Avatar
bad bill
Stage IV
BClem,
After going through all of the ignition, I went to the fuel. First was int. gasket change then a spare carb was tried, still no luck!
As said in orig. post ,compression had little/no problems showing.
Anyway, out of sheer desperation I pulled the cam cover for a look.
Inside I found a faulty lifter which had "Hammered" the exh. lobe on the front cyl. An evl 3000 V-Thunder cam, Crane big axle lifters,S.E. crome adj. p-rods installed.... PROBLEM SOLVED AT LAST!!!!!!!!!
Oh yeah,after I got going this far no need stopping. I went ahead and did the top end along with a fresh coat of wrinkle and a ring gap check.
She is back and better than ever!!!! Thanks for the RE: BClem.
bad bill
"Don't winterize, RIDE!!!!"
Carlos Argueta
EVO
11-17-2018 02:31 AM
Aussiemadness
Carburetor Related
05-21-2015 08:22 AM
blackbear
EVO
37
10-13-2012 07:02 PM
chipdavey
Exhaust System Topics
01-21-2011 11:32 PM
doakley2
04-13-2007 02:30 PM
