07 rk cruise glitch
07 rk cruise glitch
I just installed a cruise control on my 07 road king. I ahve tried severl times to get it to engage without success. I took the handlebar controls apart again and ran continuity checks on the switches and wires all the way to the unit, and found no problems with the wires. The orange indicator light on the speedometer comes on when I turn the cruise on but won,t turn green no matter what I do. I tried the test that the dealership tech suggested,( With the bike off, turn the on off switch to the on position, then while holding the set switch, turn on the ignition switch. Which should make the orange indicator on the speedo turn green) but I still only get an orange indicator. the fuse is good also. Any suggestions??
Max Headflow
10-08-2018 01:25 PM
hdrk07_61
04-03-2008 06:26 AM
