getting bike back in shape
RE: getting bike back in shape
Change all the fluids including the brake fluid. Check all rubber for dry rot and replace, especially fuel lines and tires. Drain the gas and replace with fresh. If it doesn't run right, you may need to pull the carb apart and clean all the gunk out of it. Check spark plugs and replace if required. Check primary chain and drive belt tension. Ride it like you stole it.
FXD2003Rider
01-28-2024 04:25 AM
NUMA
11-26-2008 08:36 AM
