HEAT DEMONS GRIP WARMERS FOR HD MODELS
Anyone have these yet?
http://www.kuryakyn.com/products.asp?bn=harley&ci=3888
Heat your grips for those cool riding days. With 4 levels of heat and built in thermister, this smart system allows you to set and keep your desired temperature. The controller and switch is built right into the clutch perch clamp with L.E.D. indicators that dim for night riding. Installation works with any grip and includes everything you need for proper installation. Ride on with warm hands after you install your Heat Demons.
Note: Installation requires drilling one small hole in bottom side of left handlebar and may require re-installation of left hand grip with included adhesive.
I'd like to know how well they work....
or if you are interested too..
seems you can wire them internally or externally and use any grip type you want
you can get the control part in chrome.. and its an exact fit for a stock HD control setup on the left or right.. i forget side(replaces one of the clamp pieces there)
RE: HEAT DEMONS GRIP WARMERS FOR HD MODELS
I have them and like them. I was the guinea pig for my riding buddies who are now getting them for their ride. The install was easy. I have internally wired bars and didn't have to drill a hole either since there is already a hole at the end of the bars because of that. They look like they are a stock piece on the bike and will work with any style grips. In the pic below, you can see what it looks like with the leds on at level 4. If you hold the button in for a few seconds, it dims down for night riding.
