Winter Storage
I only park bikes in garage, so I am not introducing melting snow and air, so for me it is a little different. But I also suspect people are worrying a little to much. You ride the bike in the rain. If it was a classic I might worry more.
It does cross my mind when it sweats in the spring. But it will also do that once in a great while in the summer if I open the door.
At work when we got cabinets we don't want corrosion we install heaters. If you really wanted to get into this, you could build a crate around it and put a heater in it. Not saying i would.
I'm pretty OCD so I check the pack pretty regularly. It typically could go longer than a month but that is an easy interval to remember.
I wish I only parked bikes in the garage
It probably is a little overkill. When I was a young pup I would park my Harley in my parent's garage over the winter and forget about it. Never had an issue.
