Ohlin HD044
Mongo1958 (06-03-2024)
They are , I had them rebuilt by a place that said they could do Ohlins , one is leaking already and they have never felt right since they serviced them , same place has done a great job with Fox shocks ?
The Ohlin dealer says that a rod is probably bent and they can be fixed but I'm only $250 away from a new set at that point. They are HD039's so there the 12" shocks and I want to go with 13" , I could get the HD022 , the feed back I'm getting on FB is people raving about the HD044's that are running them , haven't been getting much feed back here.
Look in the Touring subforum, and the suspension subforum. You are not going to find what you want in this General section
They are hard to beat, especially when you also do the front cartridges. After getting the shocks set up properly, they are amazing
Stopit (06-03-2024)
There are actually quite a few posts and threads on the 044s.
I have GP cartridges in front so I'm pretty good there.
NorthWestern (06-03-2024)
Not just a better ride but also better handling,that said I have front and rear True-Track stabilizers ordered for even more improvement.
NorthWestern (06-14-2024)
Y2K (06-14-2024)
