EZ Pull Clutch and Brake Levers
I suffer from weakness in my left arm and hand as well as missing the fifth digit on my clutch hand. My 2000FLSTC has and unusually stiff clutch, perhaps a result of the big bore put on the bike when new. It is really a problem in traffic so living in NYC can be troubling.
Just found this EZ Pull kit that claims 30% less effort needed to disengage the clutch. It is supposed to have ball bearings in the clutch lever perch.
Has anyone installed this accessory on their Softail. Just looking for comments on whether this seems to be possible.
Thanks for your replies
UPDATE: I stumbled across and old post about EZ Pull claiming the finding neutral is a problem as well as clutch slippage. My clutch works perfectly as it is. Maybe I will work on getting the hand stronger
Received 8,295 Likes
Thanks for the input County. I just ordered a set in black. I thought it was funny when the sales girl said she only has the three finger model......"perfect I have three fingers
The clutch ramp was improved for lighter pull around 05. That part/kit is still available from HD. The cable may be creating some of the problem if it's several years old and especially if it's never or seldom been lubed. Both items are fairly inexpensive and should be done together.
There are other non HD east pull clutch ramps kits.
