UHaul Motorcycle trailer
Old 08-03-2022, 07:32 AM
Stopit's Avatar
Stopit
Stopit is offline
Received 1,044 Likes on 551 Posts
Default UHaul Motorcycle trailer
Any body used a UHaul motorcycle trailer to haul a touring bike ? Seems to be 2 different ones but the only one available to me is the smaller of the 2 .
Old 08-03-2022, 11:05 AM
tdrglide's Avatar
tdrglide
tdrglide is offline
Make sure you inspect tires on trailer before leaving lot
Had two bikes on this trailer. U-haul likes to do tire maintenance on an as needed basis through roadside assistance
The following 3 users liked this post by tdrglide:
Goose_NC (08-03-2022), nomoreyellowfootprints (08-03-2022), Stopit (08-03-2022)
Old 08-03-2022, 11:49 AM
BouseBill's Avatar
BouseBill
BouseBill is offline
Received 1,404 Likes on 608 Posts
I used a U-Haul 5x8 to move a 2016 Road Glide from Twin Falls to Lake Havasu City. Had no problems, The local U-haul would not rent a motorcycle specific trailer overnight, which kinda sucked.
As stated above do a thorough inspection before you leave the lot.
Stopit (08-03-2022)
Old 08-03-2022, 11:52 AM
jfl330's Avatar
jfl330
jfl330 is offline
This worked like a charm, but as previously stated, check your tires!
Old 08-03-2022, 12:22 PM
tdrglide's Avatar
tdrglide
tdrglide is offline
This was a 5X9 utility trailer with ramp. They wouldn't rent the double axle trailer onel way.
Old cracked bias ply tires. 65mph on the freeway. Roadside assistance came out and replaced both sides with new radials.
Next time I needed a trailer, same issue, old cracked bias tires. Guy says two days before he.can get new tires. Took the trailer to my house. Let some air out of one tire called roadside assistance. Told them bad tire. Hour later a guy showed up with two brand new radial tires.
Roadside assistance is contracted out to independent tire shops but you have to leave the Uhaul lot before you can call them
The following 4 users liked this post by tdrglide:
6113_ (08-04-2022), Buster (08-03-2022), HD676 (08-05-2022), Max Headflow (08-04-2022)
Old 08-03-2022, 12:28 PM
jfl330's Avatar
jfl330
jfl330 is offline
That's working the system!
The following 2 users liked this post by jfl330:
BouseBill (08-03-2022), Vec (08-03-2022)
Old 08-03-2022, 01:55 PM
SJMathisen's Avatar
SJMathisen
SJMathisen is offline
Towed my Crossbones.....but I also had a wheel chock on the front wheel. These trailers are OK....no real suspension so would cinch down the straps every so often. I have used a similar trailer on an Ultra with no issues.
Old 08-03-2022, 02:09 PM
CrBear's Avatar
CrBear
CrBear is online now
Received 4,255 Likes on 1,758 Posts
I used a U-Haul 5x8 to haul the Switchback to KC and pick up the Street Glide.
8 hrs each way and was fine, just bouncy.
Stopit (08-03-2022)
Old 08-03-2022, 04:18 PM
Stopit's Avatar
Stopit
Stopit is offline
They have a 5 x 9 sitting there they won't rent me , just wondering mostly if the ramp lets you load smoothly on the 5x8 , seems to be a sorter ramp , just wanna be sure it won't hang up loading or unloading .
I'll be sure to look the tires over , they had 2 to choose from .
Old 08-03-2022, 04:33 PM
Stopit's Avatar
Stopit
Stopit is offline
This looks to be the 5x9 , it has taller sides .
Quick Reply: UHaul Motorcycle trailer
