Exhaust Stud Came Out, How Screwed Am I?
I was replacing the exhaust gaskets because there was a leak. The nut got all the way to the end of the stud and got stuck…I had to take the stud out with the nut attached. It looks like I might have stripped the threads on the engine where the stud goes. I can’t tell if the stud entrance is supposed to be threaded all the way to the edge or if there is a small gap before the threading starts? I’ll be getting one new stud at HD tomorrow but am hesitant to put the new one in if the threads are stripped. Does this look stripped out? If so do I have to re-tap it? This blows.
I was just watching some content on replacing exhaust studs and how much of a pain they are. Was it the force of getting the nut off of the end that caused the stud itself to start un-threading? Or did you just decide to remove the stud once you realized the nut was stuck?
As mentioned above, but be aware of what they are talking about!!!
Thread chasers!!!!
They are NOT designed to start new threads!!!!!
They are designed to clean them up.
Know the difference between the two!
They look sort of similar and some people think you can interchange them.
https://mechanicalmalarkey.com/2018/08/16/taps-dies-vs-thread-chasers-whats-the-difference/
And what happened to you was that as you were unscrewing the nut, all the rust and crap on the stud was getting jammed up underneath it, it got to a point where it galled up, if you cleaned the stud with brake fluid and a wire brush prior to unscrewing the nut you would not have had that much build up of crud.
Thread chasers!!!!
a
Thread chasers!!!!
Thread chasers!!!!
IronAss (06-04-2022)
I agree with the above and would recommend the following.
Red Loctite., you want to mount the stud permanently, or at least so it's hard to remove. Do not use anti seize or any other lube on the stud in the head at all. You can use a little anti seize on the stud where the nut holds the exhaust on.
When you install the new stud, use two nuts and lock them up to tighten the stud into the head. I usually just torque them until the small vein in my temple pops out, as opposed to the big artery in my neck. That is for the fork nut.
The purpose of the stud is to permanently mount it into the head so you CAN take off the exhaust nut to replace seals etc. You do not want the stud to come out each time because it causes undo wear and tear on the head itself. If you strip out the head threads, you will have to use a heli coil to repair it, and use an oversize bolt to hold the exhaust on.
