Drain plug leak
bulldog1776 (05-01-2022)
The following 2 users liked this post by pgreer:
bulldog1776 (05-01-2022),
KW HD (05-01-2022)
Received 6,055 Likes
The following 2 users liked this post by kel03:
Glenn Gorman (05-09-2022)
You have the wrong o-ring.
You should not see the o-ring when the plug is tightened up.
The plug is sealed by the o-ring, there is no need for thread sealant, it does nothing to seal the plug (and is not called for by the service manual).
The following 7 users liked this post by Dan89FLSTC:
BrandonSmith (05-03-2022),
chief08 (05-01-2022),
grizzlygar (05-15-2022),
JimL_15 Electra Glide (05-02-2022),
and 2 others liked this post.
pretty sure there's a little recessed area on the plug that the o-ring seats into (at base of threads), and agree with Dan^^ above I don't recall mine ever squishing outward like your pic.
I bought a big bag of o-rings off Ebay for the bike. Sure, can get at dealer (did that a time or few) but then went the bulk route.
don't overtorque
don't overtorque
Yeah these are the current o rings I have, they are the right size unless I got a defective batch.
If I'm understanding you guys correctly, once I tighten it the oring should be up in the hole and the face of the plug meets the pan metal to metal?
bulldog1776 (05-02-2022)
