2007 street glide won’t accelerate past 80mph / full throttle
I have a 2007 Street glide that loses acceleration if I crank the throttle to pass someone on the highway. I am getting the following codes:
P 0152- rear O2 sensor high
P 1353- front cylinder no combustion
Pn 34455-076
i just changed all 3 oils and the air filter.
any suggestions?
Pn 34455-076
any suggestions?
well, the code give you the clue.
p1353 says you have no power output from that cyl. if you moved things around, check for bad connection. a bad spark plug or wire having high resistance for example.
the p0152 is telling you the rear cyl is running rich, not surprising as it is carrying the load and the ecm is maxing out the fuel delivery. do not run long term as it could over heat the injector from extended duty time.
Andrew Straus
03-22-2024 09:30 AM
HOTROD1300
04-12-2014 12:47 AM
