Question for those who have done the external crank breather
Old 11-01-2020 | 08:43 AM
MyFavRk's Avatar
MyFavRk
The only benefit I have learned so far from doing the breather set up is getting rid of all that sludge from going back into the engine and causing carbon build up .
Question here , what other benefits will I experience doing this , engine performance , life etc ? I've have been adding Sea Foam to my fuel to help keep things clean , I can only imagine it will just keep getting better , now that it's not competing against new oil entering the TB .
  #42
Old 11-01-2020 | 10:20 AM
Zeb Smith's Avatar
Zeb Smith
Intake and combustion chambers will be cleaner.
Performance and engine life stuff? Probably negligible.
  #43
Old 11-01-2020 | 11:39 AM
MyFavRk's Avatar
MyFavRk
A clean engine is a happy engine , I guess that's all that matters .
  #44
Old 11-01-2020 | 12:40 PM
Hoginedgewood's Avatar
Hoginedgewood
if you're disappointed with keeping sludge out of the throttle body being the only benefit, leave the stock setup. I'm very very happy to keep the sludge away from electronic components valves pistons and everything else.
  #45
Old 11-01-2020 | 01:06 PM
MyFavRk's Avatar
MyFavRk
No reason to be disappointed , just thought there was more to it than keeping the engine from building up carbon , since you mention electronics , that makes sense , appreciate your input ,
  #46
Old 11-02-2020 | 05:33 AM
MHTR's Avatar
MHTR
I've been thinking about doing this to my '18 FLDE. Does this cause any issues when the bike is inspected (I live in PA)?
  #47
Old 11-02-2020 | 07:19 AM
Iron lHorse's Avatar
Iron lHorse
Originally Posted by 60Gunner
Not sure why you would want it sucked into the combustion chamber. Do you really want to add hot oily air to what should be cool, dry air? You pistons will be a carboned up mess in no time.
I don’t believe that the small amount of oil vapors coming out of those two vents will be any more of a problem then the small amount of oil that passes by the piston rings.
  #48
Old 11-02-2020 | 08:06 PM
MyFavRk's Avatar
MyFavRk
My review , my buds who saw it , think it looks cool , so do I . I finally got a chance to get the bike out for a test run . What I did notice , is that sometime I would get a whiff of oil coming up , it's not bad , but then again it's not 90* out right now . I think I'm going to run with it next spring and see just how bad it gets . If I do decide to change it , I'll buy another cap and instead of drilling holes in the top for venting , I'll add another fitting and run the vent through a hose run along the frame towards the rear of the bike .
  #49
Old 11-03-2020 | 07:05 AM
YZR's Avatar
YZR
I ran mine through the frame and back by the LH passenger peg. It doesn’t look the greatest but I can always move it later.
MyFavRk (11-03-2020)
  #50
Old 11-03-2020 | 04:19 PM
MyFavRk's Avatar
MyFavRk
Was out for a few hrs today and not once did I get that bad whiff of oil , beginning to wonder if it may have been a vehicle close by that caused it . I have a couple more days of riding before the temp really drops , so I'll know for sure then .
YZR , just what I was thinking , after putting another fitting on the cap I can run a hose along the bottom of the frame and out passed the swing arm .
YZR (11-03-2020)
Quick Reply: Question for those who have done the external crank breather
