General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
hi all, since this week I own a harley davidson road king from 2007. Had some starting issues, seemed to be a battery problem. Now replaced the battery, it seems to work, but after 100 meters the engine and battery lights go on. what could this mean?
Check all the connections. If new battery and cables tight, check charging system (stator and voltage regulator). When one goes bad, it can take out another. Check the codes that are present also.
The VR is down on the front of the frame by your oil filter. The stator is inside the primary under the compensator. Google or search here on how to test your charging system.
