Torque Wrench
Torque Wrench
I wanted to start off by saying that I am mechanically retarded. I purchased the service manual, craftsman tool kit, screwdrivers, etc. because I want to learn how to wrench on my bike. While I was at Sears I bought I a craftsman torque wrench b/c the service manual calls for proper torque on a lot of things. Its the clicker type. Now to my question, how the hell do I know when the proper torque pressure has been met? I noticed that the handle seem to give a little, is that it? After you are all done laughing, could you folks some answers and provide some help. As always, thanks for info.
Matthew
Matthew
RE: Torque Wrench
You are absolutely right ! Once the specified torque value is met , you'll feel and hear "the click" , and the handle will give you the impression that it "gives" a little.
I don't know what model you've picked up but I hope is the one that has the dial in both Nm and ft/lbs.
RE: Torque Wrench
MKINK
Just a little tip :-
When you have finished using the torque wrench don't forget to back it off all of the way before you put it away. I have had quite a few wrenches borrowed and have come back weeks later 3/4 wound up which will affect the calibration of the wrench as it compresses the spring.
RE: Torque Wrench
To get used to using it, practice once to see how it feels. Set it to a very light setting, and put it on a nut/bolt and pull until you feel the "give". It will be very clear once you feel/hear it. The type you got are much easier to use than the old pointer on the dial type, although both styles work fine. Pay attention to whether a fastener is rated in Inch/Pounds or Foot/Pounds, there are wrenches available in both.
[IMG]local://upfiles/5434/F3056A026A934E80B8AE365DF0FEAACE.jpg[/IMG]
RE: Torque Wrench
NO!!!!!!!
Only wind it back to the lowest digit. I've been a heavy equipment (CAT) mechanic for 16 years. I still have and regularly use my Snap On torque wrenches that I bought 16 years ago. I'm sure the Craftman wrench will give you years of troublefree service. To convert from inch pounds to foot pounds, divide by 12. Your wrench has a max of 250 inch pounds--that is just over 20 foot pounds.
