Leaking master cylinder now peeling
Smoothnf (04-08-2020)
This was unfortunately a common issue on many HD models over the last few years.
If you are under warranty or have an extended service plan, this would be a covered repair. I would be very careful trying to clean up and repaint. Any debris or solvents that get into the piston and bore will likely damage the piston seals and require rebuilding.
At that point, you are almost better off replacing as they have revised the master cylinder, cap and seal design a few times and the recent kits are much less likely to leak again. Expect this to reoccur within a couple years if you clean up and repaint.
Hello and welcome.
I see a picture but minimal information seems to be provided.
No year or model.
I will take a guess it is a clutch master cylinder.
In the past when this happened with a Harley motorcycle that was out of warranty the least expensive solution was a new gasket and paint.
Replacement of gasket, light sanding and then tape area and surrounding parts of bike.
Rust-oleum satin black spray was the closest in color.
No year or model.
