My home made tour pack wall mount
Old 12-27-2019, 07:41 AM
bonecross9's Avatar
bonecross9
bonecross9 is offline
Great job i used the copper for the quick release side
and metal conduit (for running exposed electrical wiring) its the perfect OD
for the front mounting spots
anyway great job man
Old 03-08-2020, 05:06 PM
MisteredEd's Avatar
MisteredEd
MisteredEd is offline
I like your set up but I would like to load and unload while not on the bike soooo.....
Old 10-19-2020, 10:16 PM
scooper321's Avatar
scooper321
scooper321 is offline
Originally Posted by JonW
After looking at several tour pack wall mounts, I decided I could make one myself. Mine isn't as fancy, but it works just as well.
You'll need the following items:
Angle iron with holes (trust me, it's easier than drilling your own)
1/2" copper tubing
3/8" threaded rod
1/2" spacers
Vinyl tubing
Screws for whatever medium you'll be fastening it to
I chose 1/2" copper tubing since its OD is almost a perfect fit tor the front attachment points on the docking mount. One piece of the threaded rod is inside the copper tubing.
The copper tubing is just a touch big for the rear ratcheting mounts, so I used the 3/8" rod again with some clear vinyl tubing over it to protect the mounts.
Use 1/2" spacers between the angle iron and the wall to provide enough clearance for the ratchets.
Mine has 13" between the angle iron pieces (the copper tubing is 13" long). I wouldn't go any narrower than that. 14" is plenty of room and no need to go wider than that.
Pretty simple and reasonably priced.
Just made this sort of mount for my pack. Thanks for the ideas!
Old 01-30-2022, 11:56 PM
Burbur2's Avatar
Burbur2
Burbur2 is offline
I really like the idea you can load it while not in use. Can you show picture of it without pack sitting on it?
Old 01-31-2022, 04:45 AM
ratsnest's Avatar
ratsnest
ratsnest is offline
i built a rack for my Fairing/windshield that will work with a tour pack as well ... i like how you did yours
The following 2 users liked this post by ratsnest:
BelchFire (01-31-2022), Iceman24 (01-31-2022)
Old 01-31-2022, 06:43 AM
BelchFire's Avatar
BelchFire
BelchFire is offline
Moderator
Received 5,156 Likes on 1,947 Posts
All the PVC pipe they had at the hardware store was too big OD. A plumbing supply house or big box store might have had some in smaller sizes, but I didn't want to drive all over town.
I used CPVC for mine, otherwise like yours, only I drilled angle iron so I could offset the holes like on the bike mount. I can't remember what size CPVC, but I think it was 3/8"; if not, surely it was no larger than 1/2". It fit the quick release slot perfectly.
Old 02-01-2022, 08:37 AM
Cajun4x4's Avatar
Cajun4x4
Cajun4x4 is offline
Get a can of plasti-dip, problem solved.
Old 02-01-2022, 10:45 AM
dbarbee's Avatar
dbarbee
dbarbee is offline
I used aluminum tubing over the all-thread and cap nuts on the ends to give it a more finished look. I combined the homemade tour pak rack with an inexpensive wall storage system from Wal Mart for a very convenient way to store our gear.
The following 3 users liked this post by dbarbee:
Cajun4x4 (02-01-2022), DanHappy (02-01-2022), ratsnest (02-14-2022)
Old 02-01-2022, 11:36 AM
DanHappy's Avatar
DanHappy
DanHappy is offline
Received 2,419 Likes on 1,614 Posts
Very nice!!! I wish i had that amount of wall space in my garage..
Old 02-11-2022, 04:36 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,138 Likes on 2,848 Posts
Quick Reply: My home made tour pack wall mount
