Oily air filter problem solved. Air filter vacuum chamber with drain solenoid.
nicholasadam (05-23-2020)
I used the existing vacuum from the air cleaner to activate the vacuum chamber to drain oil out of the head relief. A normally open solenoid valve on the bottom of the chamber drains the oil back into fill cap. When ignition is on solenoid valve is closed to keep a closed system to drain oil from vacuum chamber. When ignition is off valve opens and oil drains back into engine. I have one installed and currently testing. Im at 500 miles so far and the air filter is bone dry. If there is any interest in these i may start building to sell. Im looking for feedback on what everyone thinks of it .
The following 2 users liked this post by Tom84FXST:
18deluxerider (10-18-2020),
Vec (08-09-2020)
The following 2 users liked this post by Rocking_it:
Vec (07-10-2019)
The following 4 users liked this post by xcbullet:
