Oily air filter problem solved. Air filter vacuum chamber with drain solenoid.
Old 06-28-2019, 11:21 AM
bustert's Avatar
bustert
bustert is offline
i really like the thinking out the box. better mouse traps are built every day by such.
not my cup of tea on this approach
mr. hey man used a good ole B&S engine design
this is what it have done
Attachment 610771
i flog the machine regularly and never an issue with oil in the cleaner.
Old 06-28-2019, 01:23 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
That may be the dumbest thing I've ever seen!
Old 06-28-2019, 02:04 PM
Hey Man's Avatar
Hey Man
Hey Man is offline
Received 7,213 Likes on 2,887 Posts
Oh but what a boring world this would be if we were all the same.
Old 06-28-2019, 03:01 PM
wbill1666's Avatar
wbill1666
wbill1666 is offline
I appreciate your input I've put a catch can past the oil filter to see what comes out. I believe 99 percent of oil is sent back to the crankcase. I've run this on my 124 for 600 miles and picked up 6 miles to the gallon with no issues. Was trying to stay in the EPA world. I believe all engines pick up a little moisture when shut down just to cook off when started. This whipped up oil hangs out in vacuum chamber until bike is shut down pretty much cooking off any moisture like any engine
Old 06-28-2019, 03:08 PM
wbill1666's Avatar
wbill1666
I've seen that done alot,i was trying a solution that would work with EPA without pissing all over your leg . I've run for 600 miles. Only issue is I picked up 6 miles to the gallon with my air cleaner being dry ,makes a big difference on a 124
Old 06-28-2019, 04:38 PM
Tired's Avatar
Tired
Tired is offline
Received 4,816 Likes on 1,761 Posts
While I can appreciate the thought and development of your fix, it does seems a bit involved and overboard.
Kinda like you saw a cockroach and burned down the house to kill it.
The following 2 users liked this post by Tired:
crazytown (07-01-2019), Vec (07-10-2019)
Old 06-28-2019, 06:34 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
6 mpg increase? Using that thing?
Old 06-29-2019, 08:23 AM
bustert's Avatar
bustert
bustert is offline
i could see that if he let the filter soak through and through with oil, clogs the pores and acts like a choke.
my mileage is grin factor controlled, can range between 30> near 60 mpg. main thing is not to let the 200 main jet kick in.
Old 06-29-2019, 09:33 AM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is online now
Received 4,089 Likes on 2,043 Posts
Just a guess ...are you plumber/ pipe fitter? I really like seeing the stuff people come up with. In this case it just seems like a very complicated setup for a very simple problem. I realize it's just a prototype but it's not pretty...i know I wouldn't add it to my bike. Not sure I like the idea of that goop getting put in the motor...the reason why alot of people to vent to the atmosphere to begin with. If you can clean up the design and either chrome or powder coat all the visible stuff maybe you'll find a market...just tell people it increases horse power and torque by 10 percent lol...but seriously good luck with it.
Old 06-29-2019, 09:47 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 6,017 Likes on 4,064 Posts
Definitely an interesting setup. From what I've seen, you will likely still get some mist into the intake as you collection reservoir is a little small. You'll see it when running at higher speeds for extended periods of time.
18deluxerider (10-18-2020)
Quick Reply: Oily air filter problem solved. Air filter vacuum chamber with drain solenoid.
