12 inch handle bars
I just replaced my stock bars with KST Six Bend Kicker 10", the manufacturer told me I didn't need to extend anything. When I ran the wiring outside the bars as the stock bars were I had plenty of excess wiring. But the KSTs required internal wiring in order to operate properly and this required all the slack I could get from inside the fairing. Anything taller than the 10" and you will need to extend everything.
Do it right, extend the cables...otherwise (1) your clutch will slip during hard right turns and (2) you'll have everything tight like a guitar string which will strain cables. I initially stuck w/stock cables on my '09 FLHX, but did a ton of under-fairing clean-up & re-routing. Ended up extending the clutch cable (later), but I did swap TBW during install.
Trust me, if you're going to go through all that work, swap the cables.
